I'm officially in the club - please help - Defender Source
Old June 25th, 2013, 11:35 PM
jt2127's Avatar
jt2127
John Thomson
2010 Sport & 2013 LR4
After about 20 months with my D90, she finally left me on the size of the road.
First, I lost power to the radio. Then the battery went. After a jump I hit the road for home. A few minutes in the radio went out again. Then about 10 minutes in the engine lost power. Couldn't get her above 45mph, then 25-30 mph. Then I pulled over and called for a tow. I've been idling for 15 minutes no problem. Heard some knocking before pulling over.
I recently had two Hella 4000's installed. Turned them on briefly for the first time tonight.
Check engine light came on after the jump.
Would greatly appreciate the collective genius of this forum to help me trouble shoot.
------ Follow up post added June 25th, 2013 10:41 PM ------
One more detail. While in idle, if I try to give it gas it wants to die and hole/gasp.
Thanks.
Old June 25th, 2013, 11:54 PM
$5 test light from walmart and see if the alternator is putting out 14v.
What year is this beast?
Old June 26th, 2013, 12:58 AM
jt2127's Avatar
jt2127
John Thomson
It's a 94 ST (no 89). Tow truck driver was willing to bet $1000 it was the alternator.
Then he went on and on about Defenders. I'm in Kansas City so they're pretty rare here. He took a picture before he left. Funny.
Appreciate the help!
Old June 26th, 2013, 01:22 AM
If Rev counter no longer works then new alternator time.
Old June 26th, 2013, 01:56 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Buy a cheap ($10) volt/ohm meter so you can see what voltage your alternator is putting out. You can check many other things too.
Old June 26th, 2013, 05:28 AM
maleger
Marc-Andre Leger
When replacing alternator also replace belts. They could be loose.
Old June 26th, 2013, 08:10 AM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
I bet it's a ground issue. Disconnect the wiring for the newly installed Hellas at the battery and see if the hesitating and stalling disappears.
Cheers
Jay
Old June 28th, 2013, 01:22 PM
jt2127's Avatar
jt2127
John Thomson
Jay- You're the man! The shop that installed the Hellas left a loose wire (wired to the alternator) that caused an arch/short.
Easy fix. Alternator tests out fine.
Thank you guys for the great input!!
Old June 28th, 2013, 11:41 PM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
Good news!
The lesson I'd take from this - don't let a "shop" do a job that you can do yourself! A Defender is just a big Meccano set!
But I don't let anybody touch any of my stuff, unless it is really necessary...
Jon Fund Off Road Club TurkD90 Defender Technical Discussions 1 January 27th, 2006 11:50 AM
SpanishTrailRovers.com now officially DEAD & GONE norros Misc. Chit-Chat 15 September 12th, 2005 09:44 AM
Ohio Land Rover Club Dfndr90 Misc. Chit-Chat 1 August 14th, 2005 10:10 PM
Sierra Club Wankers Monkeyboy Misc. Chit-Chat 12 June 5th, 2005 11:23 PM
Blue Ridge Land Rover Club PT94D90 Misc. Chit-Chat 1 March 7th, 2005 10:21 PM
