Igniton switch / lock removal - Defender Source
Old September 1st, 2014, 03:15 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
How do you remove the ignition switch? Is it pressed in?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 1st, 2014, 03:20 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
It held together with bolts that have the head shear off (by design) when torqued. It's a theft prevention thing I guess. You may have to drill them out.
Old September 1st, 2014, 03:30 PM
the rover shop
shayne young
You can usually get a small chisel and tap it out by using the chisel on the outside edge of the bolt head and get it to turn..once it turns its easy to get out.. Once the assembly is out you can then remove the ignition barrel from the housing by placing it in position 2 and pressing in the locking pin and the barrel assy pulls out...
Old September 1st, 2014, 03:36 PM
lordhelemt's Avatar
lordhelemt
Paul
I guess ill drill them out since the bolt heads are not exposed. U guess ill try my ez out first
Old September 1st, 2014, 11:14 PM
lordhelemt's Avatar
lordhelemt
Paul
Drilled and used the ez outs and the bolts backed out , no problem. Thoughts on replacing with the bolts with the original heads that shear off or just use regular cap bolts?
Old September 1st, 2014, 11:30 PM
the rover shop
shayne young
Just use Allen headed bolts..
Old September 1st, 2014, 11:34 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Locks, any lock, only buy you time, time a thief often doesn't have.
You could use cap bolts but then I would fill the bolt head surround with JBWeld.
Put tape over the bottom to hold the weld in until it drys.
Or you could buy the sheer bolts from Trevor @ RovahFarm.
Old September 1st, 2014, 11:38 PM
the rover shop
shayne young
An experienced thief doesn't need to do anything with that.. A pair of channel locks and the whole head of the ignition lock assy comes off in 3 seconds flat..and then a flat blade screw driver turns everything and let's you start it..
------ Follow up post added September 1st, 2014 11:38 PM ------
Read the x-engineering article if its still up..
Old September 1st, 2014, 11:52 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Do you mean to say that the key cylinder is removable from the assembly on the NAS D90 ?
I thought it was held in by a drive pin in a blind hole.
Old September 2nd, 2014, 12:04 AM
the rover shop
shayne young
Sorry, you may be right on that one.. I may have it confused with a later one I did this last week..I have one sitting on the desk at work and I'll take a look..
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
Door lock cyclinder removal? 97-D90-736 Defender Technical Discussions 0 October 4th, 2010 05:43 PM
Lock Cylinder removal bjf Defender Technical Discussions 9 July 28th, 2010 07:49 PM
SW Rear Door Lock Removal mpsteil Defender Technical Discussions 2 November 2nd, 2009 08:15 PM
