Ignition WTF? - Defender Source
Old December 16th, 2012, 09:26 PM
mattwhite
Matt White
94 D-90
Ignition WTF?
So my '94 has a no spark issue. In the process of tracking the problem my ignition switch fell apart (plastic separated from the metal piece). Prior to the switch falling apart the car would crank but no spark at the dist. After it came apart, I tried chasing the wires on the ignition switch. The brown wire should be 12v from the maxi-fuse in the engine bay.
Now here is the WTF part: The brown wire is not getting any voltage. But the voltage measured from the electrical connector on the back side of the maxi-fuse block is 12.4. According to the wiring diagrams this wire should run directly to the ignition switch. There doesn't seem to be any cut wires so I'm guess there's something else between the two.
Anyone have any suggestions?
Matt
Old December 16th, 2012, 10:02 PM
Ignition module.
Old December 17th, 2012, 12:17 AM
mattwhite
Matt White
94 D-90
That's probably part of the issue. About a year ago, I was working on the dist. and replaced the ignition module with an AB relocation kit. Then about once a month I started to have a no spark issue (extremely intermittent). However, if you killed power from the battery it was like a reset and it would then start right up. I messed with it for a while then put the old ignition module back on and didn't have any problems until now. I swapped the "new" one back on and got nothing. Sooo, yes both could be completely bad, but the new "AB" one was working for the most part when I took it off.
Any ideas on power to the ignition switch?
Matt
Old December 19th, 2012, 11:12 AM
mattwhite
Matt White
94 D-90
Mystery solved.
Apparently the maxi-fuse in the engine bay labeled "ignition" does not supply 12v to the ignition switch and starter relay. It's the fuse labeled "lighting" actually supplies power to the switch and relay.
Maybe it's one of those British things, they say hood which translates to soft top, we say hood which translates to bonnet.
And the new ignition switch seemed to solve the no spark condition. Not sure of the correlation there but it has decided to run at least.
Matt
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
