Ignition won't turn off - Defender Source
Old July 19th, 2012, 04:40 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
When I park the truck and turn it off the ignition won't return to the off position. I can't remove the key either. The engine turns off but the ignition remains in the first accessory position. Is it just my ignition switch that has gone bad?
Thx
Old July 19th, 2012, 10:31 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Auto? There is a sensor and interlock on the shifter that makes sure you are in park. Its also tied to teh brake pedal.
-Jeff
Yes. That seems like it might be the issue. How do I fix it?
Old July 19th, 2012, 10:36 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Check your trans shifter is fully in park, check your t-case shifter is fully in high or low, check your brake lights are working. If not then the lock will not release your key.
Sent from my iPad using D-90 Source
Old July 20th, 2012, 06:28 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Auto trans.
Positioned in Park.
Transfer case in 4H.
Any suggestions on how to work through this?
Old July 20th, 2012, 06:46 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
Originally Posted by mdmccallum View Post
Auto trans.
Positioned in Park.
The brake light switch is part of the system too.
I had the identical issue. Turned out that the TC was in gear but the lever was just forward enough that the switch thought it was out of gear. Double check it.
Old July 20th, 2012, 09:56 PM
RickM
Rick Mabus
95 D-90 ST
I had my key module brake on me. Wound up having to replace the key tumbler.
Old July 21st, 2012, 02:52 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
At the advice of others here, I pried the cover off the Auto Shifter handle and sure enough, the plunger mechanism thingy was stuck in the upright "drive" position. I've sprayed all sorts of crap down it to make it fall when I shift to park but have resorted to diving her a hit of my fist when I go to remove the key. I really need to take it apart I guess.
Old July 21st, 2012, 04:03 AM
Captain Spalding
Captain Spalding
At least you've identified the problem. That's huge.
Old July 21st, 2012, 04:53 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I Figured it out. It was the button in the shifter knob. It wouldnt fully release. All is good now.
Thanks everyone.
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition key won't turn! cgalpin Defender Technical Discussions 11 March 27th, 2010 06:42 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
