Ignition Wiring Question - Defender Source
Old November 23rd, 2013, 04:02 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Where does the black wire ground to on a 1986 diesel ignition switch? I traced the wire and found it just exposed not connected to anything...
Thanks in advance
Old November 23rd, 2013, 08:06 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
After doing some reading, I assume it connects somewhere to the multi earth in the wiring harness. For a temporary fix could I just run a bit of wire to the earth on the engine side of the bulkhead or would that produce and danger? I'm pretty new to wiring so I'd like to check with the forum before I change anything.
Old November 23rd, 2013, 08:10 PM
Are things working properly now?
If so, cap it off and leave the spirit of Lucas alone.
Old November 23rd, 2013, 08:16 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Tough question, the past few times I tried it hadn't started. So for good measure I cleaned the ground on the bulk head but it looked fine anyways. It was turning over before I did that but wouldn't catch, I then found out it was in 3rd gear when I was trying to start. Tried today when it was in first and it came close (chugged forward a little b/c the clutch wasn't fully depressed) but then the battery died (tried too many times I guess) so I'm recharging it now. I doubt changing it from 3rd to 1st did anything but this car seems to be possessed at times.
My concern is I figured the ground was there for a reason and trying again with it disconnected could be dangerous.
wiring
Ignition wiring question 94 90 Doug Crowther Defender Technical Discussions 5 May 9th, 2007 08:02 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
