ignition wiring help needed.. - Defender Source
Old January 19th, 2014, 03:54 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Welp, I opened Pandora's box....
Was removing an old alarm system on a 95 Defender 90 Wagon and need the wiring diagram or at least some insight on where the wires go from the back of the ignition switch. And by switch I mean the back of the metal body that you stick the key into that goes into the the dash...I removed instrument cluster (will need help figuring out those wires later) and am tracing the wires from the old alarm...
Thanks Board!
Old January 19th, 2014, 09:37 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
This pinout is for a later model, but I believe there's little to no difference between it and the wiring on the NAS trucks. Should get you close if it isn't exact.
Geared Restoration Co.
352-572-3236
Old January 19th, 2014, 10:49 PM
kevincdoyle
Kevin C. Doyle
thanks a gazillion...
Ok, one step at a time. I read this that there should be 4 wires off the back of the ignition key switch :
1 big brown wire
2 big white wire
3 smaller white /red wire
4 smaller white/orange wire
All going to where they are supposed to or, sailing the river Styx...
KCD
wiring
ignition wiring help needed spartan Defender Technical Discussions 3 June 26th, 2013 02:13 PM
Speaker Wiring Help Needed NoVaKevin Defender Technical Discussions 10 February 14th, 2011 02:49 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
