ignition wiring help needed - Defender Source
Old June 25th, 2013, 03:28 PM
spartan's Avatar
spartan
Fred
83 D110
I have a 2001 wire harness and I just bought a new ignition unit. Im guessing I have it set up correctly but I dont want to start the engine just in case im wrong. I dont have a wiring diagram for a 2001 Defender.
there are 4 numbered prongs. Can someone tell me what color wire goes to each prong? One of the prong has a pair of connectors going to the same lead. The photo is not showing the numbers.
Thanks for the help in advance.
Old June 25th, 2013, 10:10 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Maybe these will help.
ID:	75012   Click image for larger version
Old June 26th, 2013, 07:10 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Looking at the rear from the top going clock wise:
85 V-8 Switch Brown/orange, White, open, Brown, White/Red, Open, Open
Td5: Double pin connector, White (white connector), next double pin connector, Brown/White (Black Connector), Single connector, White/Red (red connector), double connector White/Orange (Green Connector)
TD5 White/Orange (Pos 2 Aux), White (1), White/Red (Pos 4 Crank), Brown/ White (IN2)
Old June 26th, 2013, 02:13 PM
spartan's Avatar
spartan
Fred
83 D110
thanks you to both for the help. Much appreciated.
wiring
Dash/Gauge wiring assistance needed Rover110 Defender Technical Discussions 30 October 11th, 2012 09:24 AM
Speaker Wiring Help Needed NoVaKevin Defender Technical Discussions 10 February 14th, 2011 02:49 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
