Ignition Wiring? - Defender Source
Old February 21st, 2008, 07:30 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Ignition Wiring?
In the below photo does anyone know what wire 3 connects to? We have it marked on the ignition and it is disconnected becuase as soon as we connect it, it blows the big fuse in the big fuse box. We figure this means that it is either going to something that is wired right to the main fuse box, or the wire has a short. The white wire is part of a big harness that goes behind the dash and we don't want to cut into it and tear open the dash if we don't have to.
Chris and his friend Randy
Old February 21st, 2008, 08:41 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
#3 wire, White, is the ignition switched power output from the switch that feeds a lot of things in the fuse box.
Brown is the power into the switch from the maxi-fuse under the hood.
White/Red is the starter relay trigger and the white/orange is the accessory switched power.
As too why it blows the fuse...? Could be lots of things. Make sure you have the positions on the ignition switch right and then dig out the multi-meter.
Email:
Old February 21st, 2008, 10:32 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Hey Mike,
Thanks for the input, we will give that a look and get out the meter.
wiring
New Ignition Switch wiring tomaco1 Defender Technical Discussions 0 May 27th, 2009 08:58 AM
Ignition wiring question 94 90 Doug Crowther Defender Technical Discussions 5 May 9th, 2007 08:02 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
