Ignition will not spring back - Defender Source
Old August 22nd, 2013, 02:28 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
Gentlemen/Ladies,,
I can't seem to find a thread on this: When I start my 1997 D90 SW, the ignition switch does not spring back to the on position. I have to manually turn it otherwise the starter just keeps turning. Do I need a new part or can I fix this? Please be gentle as this my first post. We recently added the 1997 D90 SW #2179 to the family.
Old August 22nd, 2013, 05:39 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
It's neither gummed up nor dead. There's no resistance when turning it. The engine starts just fine. It just does not spring back to the on position. I have to manually turn the key back to the on position. It seems that a spring broke in there.
Old August 22nd, 2013, 05:57 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Mine was the opposite, but this is what you are looking for...
http://www.defendersource.com/forum/...ad.php?t=40469
Old August 23rd, 2013, 04:32 PM
Welshgas's Avatar
Welshgas
Paul Woodsford
2010 90 XS
This might help: http://forums.lr4x4.com/index.php?showtopic=84373
Old September 7th, 2013, 02:30 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
That worked. Switch replaced.
Replacing the switch was it. Finally got around to replacing it. What's nice is there is no chance of cranking the starter motor now when the engine is running. Thanks.
ac
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
