Ignition weirdness - Defender Source
Old April 5th, 2015, 04:19 PM
defdad's Avatar
defdad
Philip
1985 Defender 110 3.5 V8
Ignition weirdness
On cold mornings I come out to my 110 and there is condensation on the ignition. So much so that there is a small puddle underneath it on the floor mat. Battery is disconnected too.
Second strange thing that just started happening...when I turn the key ALL the way to start it, the dash electronics turn off (warning lights turn off & gauges go back to off position). Engine will keep turning over but I have to back the key off a bit at which point dash lights come back on, gauges turn back on, and it starts. Great anti-theft feature I suppose but it is getting a bit old!
Replaced the ignition switch this morning but same thing. Any thoughts? Couldn't be starter, correct?
Old April 5th, 2015, 04:37 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would check the wire from the switch to the fusebox. and of course the grounds.
MAF/intake weirdness artm Defender Technical Discussions 1 August 7th, 2006 06:07 AM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
Ignition problems boshea Defender Technical Discussions 7 October 7th, 2003 08:48 AM
