Ignition switch woes - Defender Source
Old May 11th, 2015, 04:23 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
My 1998 300TDI is acting up. In the mornings, I have to hold the key under pressure to get the glow plugs to heat, as the switch wants to back up. On staring, again, the switch tends to back up, so I must release the key ever so gingerly, or the engine will die.
So, am I right in believing that this probably is a mechanical issue and I should get the entire lock assembly ($), or would replacing just the electrical part suffice?
Or maybe I just need to douse the whole thing with liberal amounts of WD40?
Thanks in advance for any help!
Old May 11th, 2015, 04:34 PM
rovertrader's Avatar
rovertrader
Dale
WD40- what do you have to lose?
Old May 11th, 2015, 04:55 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
I've always liked WD40...
Old May 12th, 2015, 01:57 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
And I'm sorry to report that
No, WD40 didn't cut the mustard
switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Clutch woes... Trigger Defender Technical Discussions 8 September 9th, 2010 07:01 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
The woes of a nightmare repair job Hans Misc. Chit-Chat 13 January 26th, 2005 04:15 PM
CDL woes ToaDisco Defender Technical Discussions 10 September 27th, 2004 06:10 PM
