Ignition switch. What am I missing? - Defender Source
Old June 19th, 2016, 06:19 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Replacing ignition switch on a NAS 90 but ran into a snag. Look like the PO replaced the switch at one time with non-genuine. Ordered a genuine one from RN. Pictured. Part number LR039638. Says it the right one. Anyway. The switch when installed won't engage with the male in the tumbler. Wrong size and shape. Is there an a adapter of sorts that is missing? Wrong part sent by RN? The non oem part that was taken out obviously works but is different female connection. Any help greatly appreciated. Thanks.
Old June 19th, 2016, 08:55 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Yes. There's a little piece that couples the lock with the tumbler which falls off easily... Looks like this. Click image for larger version
ID:	152219Click image for larger version
ID:	152220Click image for larger version
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
Old June 19th, 2016, 09:41 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Damn. That is what I suspected.
Thanks. It is no where to be found as the non oem switch that was in there does not use that. So I positive it was removed and then discarded when that switch was installed.
Any idea where to find that piece?
Old June 20th, 2016, 03:04 AM
Omero's Avatar
Omero
Omar Alomar
It comes as a part of the complete lock assembly. Think I still have the box somewhere. When I get back from I'll send you the part no.
Old June 20th, 2016, 04:57 AM
Omero's Avatar
Omero
Omar Alomar
Ok... Part no is: LR041320. You can find it on www.lrdirect.com
switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Strange voltage on accessory ignition/stereo switch Neo Defender Technical Discussions 1 November 1st, 2006 09:39 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
