Ignition Switch? Turns itself off. - Defender Source
Old October 9th, 2012, 10:18 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
The vehicle starts but as soon as I let go of the key it turns itself off? If I physically hold the key I can keep it runnnig but again when I let go it turns itself off.
Do I just need to replace the entire switch?
Thanks in advance as always!!
------ Follow up post added October 9th, 2012 08:20 AM ------
After searching:
http://www.defendersource.com/forum/...gnition+switch
Looks like the same problem?
Old October 9th, 2012, 10:22 AM
The little switch at the end of it has probably come apart. I have a thread on it with pics if you search under my name.
Old October 9th, 2012, 10:35 AM
Quimbola's Avatar
Quimbola
Josh
I would agree, but I just replaced that part. This is acting different, when that switch went I got no power/lights and the key acted normally.
This time it seems the key just won't stay in the "on" position.
I think I need this part?
http://www.roversnorth.com/p-17080-s...-defender.aspx
Old October 9th, 2012, 07:49 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I got the whole switch and lock with two keys from Rovahfarm for $75. My switch was for an '84 defender. I don't know what the price would be on a '94 switch / lock. I just installed mine this weekend. I had a very similar problem... my switch had a bad spot where the voltage would drop to 3 volts and the car would stop if the key / switch would return to that specific spot after returning (springing back) from the "start" position.
Old October 9th, 2012, 08:32 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
you can get just the electrical part thats what you need .....
No Mall crawler here
Old October 9th, 2012, 10:17 PM
Quimbola's Avatar
Quimbola
Josh
OK, so the electrical piece controls keeping the key in the "on" position?
When that piece split two months ago and I replaced it I don't recall it effecting the key, it only seemed to involve the electrical contacts.
Old October 9th, 2012, 10:23 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
the electrial switch is spring loaded internally when you let go of the key it will return to the run position
Old October 9th, 2012, 10:57 PM
Quimbola's Avatar
Quimbola
Josh
Ok, I'll bow to the forum knowledge.
Josh, was this the one you ordered?
http://www.partsgeek.com/catalog/199...on_switch.html
Part Number: W0133-1651203
Old October 10th, 2012, 12:20 PM
Yes,
W0133-1651203
It's now at the top of your link instead of the bottom.
Old October 10th, 2012, 01:47 PM
Quimbola's Avatar
Quimbola
Josh
Thanks Josh.
Old October 16th, 2012, 11:36 AM
Quimbola's Avatar
Quimbola
Josh
Again thank you to the forum, put in new switch and all is good to go!
Old October 16th, 2012, 11:41 AM
Did you buy 2 this time?
Old October 16th, 2012, 03:30 PM
Quimbola's Avatar
Quimbola
Josh
I should have. The first one only lasted three months. I should have known, after the first install the key never felt quite right.
switch
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
