ignition switch retaining screws - Defender Source
Old March 30th, 2013, 12:14 PM
Does anyone know the correct size/thread pitch for the two little screws that hold in the ignition switch? I'm replacing my switch and the existing one only has one screw and it's a bit smaller diameter and a course thread anyway. I'd like to get two screws that are the right size.
Originally Posted by pendy
I'm here for the D's
Old March 30th, 2013, 12:55 PM
No the tiny little screws that hold the switch in place
Old March 30th, 2013, 03:21 PM
Thanks. Home Depot didn't have anything close so will try ace hardware in a bit. There are threads in the switch housing which look fine threaded to me. Are you saying they look coarse? Can you take a (better) picture of one?
Old March 30th, 2013, 07:57 PM
Thanks for checking. I didn't make it to the hardware store today, but maybe tomorrow. Would you mind checking the length too please?
I wouldn't be able to tap both sides without removing the shear bolts so doubt I'll go that route. Will give getting the right screws the old college try.
Old March 31st, 2013, 12:48 PM
It appears a 2-56 x 3/8 is the best fit. Thanks!
Old January 14th, 2015, 11:38 PM
I just did this job tonight and one of the screws caused interference inside the ignition switch. Just thought I would mention that. Thanks for taking the time to figure out the size. I think the ones on my truck are longer than 3/8. Which could explain the problem.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
switch, wiki
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
