Ignition switch, need advice, - Defender Source
Old July 20th, 2015, 01:22 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
300 tdi, I have replaced the ignition switch 3 times, it works for several months and then it won't start again, my question is, am I getting bad switches or could it be an electrical problem causing the switch to go bad,
Old July 20th, 2015, 01:27 PM
are you sure its not the starter solenoid or relay ?
Old July 20th, 2015, 01:32 PM
CavemanDiesel
Eric Smirh
1985 D90
No, I'm not sure, but I replaced the starter about a year ago, I'm on my 3rd ignition switch, I'm a novice on on these things ,
Old July 20th, 2015, 01:47 PM
the switches are crap but shouldn't be going like that.
Old July 20th, 2015, 01:48 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It sounds like your are burning the contacts on the start position.
It also sounds like you hooked the start position on the starter switch straight to the starter solenoid.
If this is true, then hooking a rely between the IG switch starter position and the starter solenoid would prevent the contacts from getting burned provided you hook the relay up as follows:
86 (+) from IG SW start position (white with red)
85 (-) Negative ground (black)
30 (+) from Battery (brown)
87 (+) to starter solenoid start position (white with red)
RDavisinVA
Old July 20th, 2015, 01:50 PM
I've had issues with Ignition Switches...replaced it a couple of times, but mine seem to at least last a year or two. But then they de-laminate and the back of the switch starts to come off. Got sick of it the last time (just the other month) as I was leaving on a wheeling trip in literally a few hours. Rigged up a push-button Carling start and have actually been loving it!
Advice on 3.9l distributor/ignition setup WildBoar Defender Technical Discussions 10 March 20th, 2015 03:34 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Desperately need PRC2735 ignition switch Sandt Wanted 0 April 1st, 2013 10:29 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
