Ignition Switch issue 89 Def 130 - Defender Source
Old June 11th, 2016, 08:38 PM
AustinAAD90
Greg
94 Defender 90
Hey gang. Hoping you can get me out of the frustration station. I had an otherwise fully functional 89 defender die on me, only to find the positive feed to the ignition switch was fused, and blown. Jumpered to get 12V to the switch, turning the key caused a click in the dash, but no action from the starter. It wasn't a low-voltage starter click, but a smaller click somewhere behind the gauge cluster. What am I looking for?
Old June 13th, 2016, 02:53 AM
Thiemo's Avatar
Thiemo
Thiemo Ebersberger
1989 4 door pick up 110
Likely a faulty ignition lock. At the end of the barrel/ housing is the electrical side. A small round casing. All wires are connected to it. Detaches by taking the two allan grub screws out. Available as a separate part PRC 8230.
What ever you do do not replace it with Britpart. It only last about 5 seconds.
Old June 13th, 2016, 08:07 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Greg:
You didn't state what engine you have which will most likely effect the type of ifnition switch tou have. There is a starter solenoid in the fuse box area that could be the clicking you heard and could need replacing.
Another ass clown wiring scenario.
The brown wire to the ignition switch is NOT fused.
Even with a high amp fuse, it would still heat up due to all the switched connections running through the fuse.
Bypass the fuse by running a new wire from the large battery cable lug on the starter solenoid to the ignition switch.
I get in arguments all the time with people who "over fuse" every circuit like the glow plugs and then wonder why the 70 amp draw is melting the fuse.
You should start with the ground. If you have a bad ground, it could stress the other side (+) of the circuit and cause the wire to pull extra hard and blow the fuse.
Then work your way out from there.
Be careful as there could be a short somewhere on the (+) side and the fuse was put in to mask the short.
If there is a short, you'll need to find it and eliminate it to prevent the loom from smoking.
Good luck.
RDavisinVA
130, switch
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
Ignition issue Ai91 Defender Technical Discussions 7 August 4th, 2015 10:24 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Constant Audible / Ignition issue--AHHH! minch77 Defender Technical Discussions 14 April 30th, 2012 11:20 AM
Crazy $$$ Def 130 gsv The Flea Market 27 October 18th, 2011 04:15 PM
