Ignition switch - Defender Source
Old January 9th, 2005, 05:41 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
Ignition switch
The 90 went almost a whole 6 weeks without a problem! The ignition switch is dead, car tries to turnover but when I let go of the switch it turns off.I attempted to change the electronic part of the switch. I pulled the switch out ,the metal piece that fits in the slot of the electronic switch also came out stuck in the slot.I pushed the piece back inplace and put another electronic switch backin. When I tried to start the 90 nothing happened even when I played with the switch.How hard is it to change the mechanical part of the switch? Anyone have the same problem before?
Old January 10th, 2005, 01:12 PM
Hey George, long time no see hope this helps!
http://www.defendersource.com/forum/...gnition+switch
switch
Ignition switch jumping jellyfish Defender Technical Discussions 1 October 15th, 2009 11:50 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
