Ignition switch - Defender Source
Old September 21st, 2009, 07:52 PM
jumping jellyfish
Ty
1993 NAS Defender 110 286/500
Ignition switch
The electrical portion of my ignition switch disintegrated. It was completely apart with only the metal shell of the switch still in the lock cylinder. I got a new genuine switch. Problem is there seems to be a piece missing between the keyed shaft from the lock cylinder and the white nylon part of the switch. What does that piece look like? Thanks in advance.
Old October 15th, 2009, 11:50 PM
RickM
Rick Mabus
95 D-90 ST
I had the same thing happen
I had the exact same thing happen. To be honest I drilled out the rivets and pulled the key tumbler put it back together and drilled it back in. The piece you are referring to does not sound familiar. You are lucky your worked out the way it did. I burned up my starter to figure out my key tumbler was messed up.
switch
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
