Ignition rewiring questions - Defender Source
Old October 14th, 2013, 07:50 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Well the engine is in thank god. Now it's time for some rewiring. I went from a points set up to electronic ignition from a 91 RRC.
1. What needs to be hooked to the 3 connectors on the distributor and in what order?
2. The current coil is a resistor coil, do I need to swap that out as well?
Then I have to sort out the alternator wiring, and extend it to the other side of the engine bay.
Unknown Author
716-898-8153
Old October 14th, 2013, 09:24 PM
The Dro
Dro
1988 Ninety
Glad to see that the motor is in.
Can you mount the coil somewhere else?
I'd hate to see that the crappy reservoir cracks and shorts your system.
Old October 14th, 2013, 10:04 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
You and me both. I could move it but I still need to wire the thing
Unknown Author
716-898-8153
Old October 14th, 2013, 10:31 PM
Get the Mallory coil I switched to. It's badass
Old October 14th, 2013, 11:11 PM
A windshield washer bottle crack and short out his coil ? What an active imagination you have Pedro.
Old October 26th, 2013, 06:49 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Ok so I figured out the amp wiring on the side of the dizzy to the coil. Anyone with a early 110 that can tell me which side + or - that the white wire goes to or the white with purple? Looking at the wiring diagram I think the white with purple goes to the + on the coil but for the life of me I can sort out what the hell I do with the white wire.
------ Follow up post added October 26th, 2013 05:50 PM ------
Its times like this I wish Trevor the Rover whisperer was nearby.
Unknown Author
716-898-8153
wiring
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
