Ignition problems - Defender Source
Old October 6th, 2003, 09:16 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Ignition problems
It's been very foggy and wet in California lately (especially along the coast) and I'm having problems starting my d-90 in the mornings. I sometimes have the same problem in the winter after a really good rain. Anyone else have the same problem? If so, what can I do to make my Defender more reliable under these conditions? It eventually turns over....but sounds like hell.
Thanks-
Old October 6th, 2003, 09:38 PM
hmm check your dizzy cap. when was the last time it was replace. sometimes my truck runs shitty when its really rainy and humid here in the southeast. Maybe your ECU isnt getting alot with the mosture either.
Old October 6th, 2003, 09:39 PM
whats the mialge and year, elaborate on sounds like hell
Old October 6th, 2003, 10:44 PM
DBZ2009's Avatar
DBZ2009
Z
ex-1994 D90/ 2 j**ps
waterproofing(not again)
Sounds like the Rover EFI water problem again. Try spraying the distributor and electrical connections in engine bay with Wd-40. Maybe I'm wrong, but sounds like the ignition problem is water caused.
Old October 7th, 2003, 02:06 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
The problem is definately from moisture inside the engine. It has been ridiculously foggy here lately (marine layer). The truck eventually starts after about 4 attempts. It's pretty nerve racking. What can I do?
Thanks Guys-
Old October 7th, 2003, 02:08 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Philip- Sorry about that...95 ST with 55K.
Old October 7th, 2003, 08:17 AM
I thought on the 95 the ECU problem with the 94's was addressed? When was the last time you replaced the ignition stuff, that is what I attribute my poor operation in wet weather too. The problem maybe more cbvious that you initially anticipated.
Old October 7th, 2003, 08:48 AM
Does it screach like all hell broke loose? Mine did that when it got wet for a while then it did it all the time. Turned out that there wer NO brushes and a load of dirt in the starter. I replaced it and the problem was solved.
But I would first pull the wires off the cap one at a time too look for corrosion. If you find any sand it off and make sure to push real hard when putting them back on too get them seated all the way. That caused starting problems for me last winter the truck ran like $hit until it dried off.
problems
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
Need HELP Bad!!!!- Ignition and Rotor Problems Doug Young Defender Technical Discussions 0 June 10th, 2004 11:32 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
