Ignition Problem - Defender Source
Old November 21st, 2004, 04:06 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Angry Ignition Problem
I am having problems starting the 90 lately. It seems that the key core is going bad and every time I start it, the key returns to the off position. Not all the way back, just enough to turn the truck off. If I turn the key very slow and let it come back slow it will stay on. If I just crank her and let go the key returns to far. Any one have this problem before? Could it be another problem and not the key core, can I replace the core myself?
Help,
Matt...
Old November 21st, 2004, 08:26 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
sounds like it is the ignition switch. you can replace it yourself but you need to remove the steering lock to get access to it. you'll need an "easy out" to remove the shear bolts holding it in the column.
Switch part # PRC8230
Insert pithy quote here.
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
Starter, or Ignition Problem????? RickM Defender Technical Discussions 2 July 14th, 2008 02:06 PM
ignition problem Irish1 Defender Technical Discussions 4 July 24th, 2004 09:41 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
