Ignition Power - Defender Source
Old November 22nd, 2004, 09:18 AM
bjenk
Brian Jenkinson
1994 D90
Ignition Power
I don't have any power at my ignition switch, turn the key nothing. My dash is in pieces (cleaning/maintance). I am a new owner and was wondering about the workshop manuel CD that is on ebay. Does anyone have this CD and does it give a good wiring diagram?
Old November 22nd, 2004, 09:27 AM
Someone posted that they bought the CD and they were happy with it. Not sure that it had electrical diagrams though. does anything else work? Like the hazard lights or head lights? Did any fuses get blown?
Old November 22nd, 2004, 12:14 PM
bjenk
Brian Jenkinson
1994 D90
Thanks Mike, I notice there is a lot of info about the cd-rom right now in this forum. I think I am going to pick one up. Yes, I have power to the lights, ect. However, I get nothing when the key is in the ignition.
Old November 22nd, 2004, 12:38 PM
Hmmm, I had the same thing happen in Jimmy's 90, but it was the battery cable that came loose. If you don't get one by this weekend let me know and I'll e-mail you the wiring for the ignition.
Old November 22nd, 2004, 01:57 PM
bjenk
Brian Jenkinson
1994 D90
Thanks Mike, my email is brianjenkinson@msn.com.
Old November 22nd, 2004, 02:18 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Fuse 5 (15 amp) powers the switch if that helps.
Old November 22nd, 2004, 02:45 PM
bjenk
Brian Jenkinson
1994 D90
Anthony, Thanks I will look tomorrow after work (24 hour schedule). I did not see any fuse labled ignition in the fuse box....FYI, I purchased a set of wing protectors for $99.99 from British Pacific, everywhere else it was over $200.00.
Old November 22nd, 2004, 04:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I *think* that fuse may be in the engine compartment against the bulkhead next to the clutch fluid resevoir. Maybe. I think.
(voltmeters are your friend with these trucks)
Good luck,
Tony
Old November 22nd, 2004, 06:22 PM
bjenk
Brian Jenkinson
1994 D90
Big fuse in the engine compartment labled ignition was good. I checked that yesturday. I have not gotten out my meter yet. Will spend some quality/quantity time tomorrow....
Old November 22nd, 2004, 07:20 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could be the ignition switch--they have a history of going out. I just replaced mine last month.
Switch/Wiring Question: Stereo Ignition Power Override nimbusnic Defender Technical Discussions 3 June 30th, 2008 01:05 AM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
