ignition module - Defender Source
Old October 16th, 2008, 08:57 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
ignition module
Im buildig a 90 up from scratch and one of the problems is that LR has changed so many parts from year to year. My current dillemma: I have an old style 2 pin ignition module mounted to the side of the distributor and the engine harness is from a later model truck that connects to the 3 pin remote mounted module. Does anyone have a suggestion on how to adapt the newer harness to fit the older ignition type? There is an adapter that allows you to go from the old style to the new but not the other way round.(at least I havent found it yet)
There are 2 wires on each, can I simply splice these? The wire colors dont match so I am leery.
should I just fork out the cash and get the remote ignition module and will this work with the distributor I have?
Keith
...you'll feel better in a couple of days.
Old October 16th, 2008, 01:05 PM
rgrrvr's Avatar
rgrrvr
1995 D90
so then I just blank off the engine harness there and bypass the distro mounted ignition mod? Its $94.00 now with a new oil cooled coil. Lower than DAP or any others. Did you have any issues with vacuum advance?
Old October 16th, 2008, 01:54 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
If you want to go with an HEI swap, I'm just about to change over to a mallory distributor, and have an HEI module you can have for free. Only been in the truck since July or so. I've also got a stock coil I'm parting with as well.
Just make sure to re-time the distributor when you do the HEI swap. Depending on which way you wire it, it will swing about 10degrees of ignition timing.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 16th, 2008, 02:31 PM
rgrrvr's Avatar
rgrrvr
1995 D90
sure Hans that'd be great, thanks! PM sent
mod
Distributor OR Ignition Module? tdn Defender Technical Discussions 12 December 7th, 2010 12:52 PM
Who is the ignition module / pickup coil authority here? dnp Defender Technical Discussions 30 August 22nd, 2008 03:14 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
