Ignition lock surprise - Defender Source
Old May 18th, 2011, 09:43 AM
NEK90
J Pinkham
1984 90
Question Ignition lock surprise
I have a 1984 ROW 90 LHD something is always wearing out- the latest casualty is the ignition switch. Looks simple to replace except for the security bolt on the steering shaft clamp-it's recessed and I can't get a good look at it but it appears it will have to be drilled-of course it will be hardened. Question- what is the proper way to deal with this- I'm out of ideas except for drilling--any suggestions? Thanks in advance- now what will be the next surprise/challenge?--Thanks-John
Old May 18th, 2011, 09:52 AM
Drilling will be best. I almost did it but did it the long way instead.
http://www.defendersource.com/forum/...ad.php?t=26677
ECR's suggestion:
http://www.defendersource.com/forum/...43&postcount=6
Old May 18th, 2011, 10:07 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Yep, just what Josh said: unscrew the two little screws that hold the ignition switch in the tumbler assembly. Then just pull it out- if you're lucky.
Old May 19th, 2011, 01:57 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I have drilled out and then used regular metric bolts to reinstall. This makes it field serviceable if you need to pull the ignition switch on the side of the road.
Ignition switch key lock revtor Defender Technical Discussions 5 December 4th, 2006 06:32 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
