Ignition issues - Defender Source
Old December 9th, 2005, 11:12 PM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
Ignition issues
It's been wicked cold here for the last few nights (-25) and the D would not start on Thursday morning. I could hear the fuel pump and the starter was working it would just not turn over. I left it and hoped the warmer weather (it was 15 today) would fix the problem. When I went to start it this afternoon the key moved back and forth freely without any resistance and any fuel pump/starter. The lights work and the accesories are also working. Any ideas what it might be? I would rather ski tomorrow than work on the truck. Thanks,
Old December 9th, 2005, 11:28 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Got headlights? What's your voltage?
With temps that cold, my guess off the top would be a dead battery that was probably on the way out for a while. If it's that far gone, jump starting probably won't work either. Got another one to try?
-Hans
What does 'no resistance' on the key mean? Does it feel like the ignition switch is busted?
My oil line fix
My 100k stopped odometer fix
Old December 9th, 2005, 11:43 PM
Hoss
Jeff Sturgis
1995/D-90
1. Check the battery. Subpar at that temperature is suspect. I would take the battery out and charge it after it has warmed up inside. Vector or Battery Tender charging inside all night will eliminate the issue of the battery if all is working well. Sounds like turning the key full travel last try did not spin the starter or make the fuel pump work, which suggest a power related issue.
2. Fuel line issue. You mentioned that you have lights and can turn the starter. Fuel pump is humming but no juice to turn it over. At -25 something can be frozen. Can you verify that the fuel line is flowing?
3. Now you know why I live in San Diego.
Here is hoping it starts next attempt.
Old December 10th, 2005, 12:02 AM
Seanh
Sean Hanagan
Hans,
It does feel like the ignition is busted/frozen. I dont know what the ignition looks like inside but the distinct sections you feel as you turn the key(acces mode/panel lights/start) are not there it just feels like a smooth barrel.
Old December 10th, 2005, 02:51 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
The ignition in my 94 d90 went a little while back it was the actual mechanism that the key goes in. that could be in your case... is it turning at all right now?
Old December 10th, 2005, 09:48 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
there are 2 parts to the ignition switch...the key/lock mechanism and the switch itself. The detents are in the switch portion. I would remove the instrument binnacle and see if the 2 halves of the switch separated...they are crimped together and may have separated in the cold. If you have really good karma, you may be able to reseat the switch halves and recrimp. If its come completely apart, you will probably need a new switch.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 12th, 2005, 09:44 PM
Seanh
Sean Hanagan
Anyone have ideas on part number/numbers?
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Hyfire ignition box Davis Defender Technical Discussions 1 April 23rd, 2005 11:29 AM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
