Ignition issue - Defender Source
Old August 4th, 2015, 12:27 PM
Ai91
Anthony
97 defender 90
Ignition issue
I know there are other threads on here but none of them seemed to be the problem I am having. When I turn the truck on the key moves free like there is nothing controlling where the key ends up after it starts. It gets stuck just past the on position but when I try to move it back to where it should be it just turns off and won't stay in the position. Any idea what this could be?
Old August 4th, 2015, 12:57 PM
The switch is broken.
Old August 4th, 2015, 02:06 PM
Ditch the ignition switch all together, and go Carling rocker switch (with a hidden kill switch or two : ). After replacing mine 2-3 times over a few years (with brand new Lucas each time) I got sick of dropping $50 on new switches as annual maintenance. Email me for details.
Old August 4th, 2015, 02:47 PM
Old August 4th, 2015, 06:59 PM
Departing90
Sasha
95 D90
The part you need is PRC8230
Its 39.99 from Atlantic British. Ive ever seen 1 go bad on a Nas defender and that was after 19 yeas of service. You'll also need 2 sheer bolts or you can use regular bolts if you like. The bad one I came across was repairable. I opened it up out of curiosity and it has several retension springs, regular springs and ball bearings. The grease had dried up.
Old August 4th, 2015, 07:13 PM
I've had 3 go out in as many years. And 1 was just replaced 1.5 years ago with a new unit.
Old August 4th, 2015, 09:12 PM
Departing90
Sasha
95 D90
I read your post. Im not trying to start a debate with you. You shared your experience as did I. Im sorry you had to go through that several X. I have no explanation for it.
Old August 4th, 2015, 10:24 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
I to agree that it is part number PRC8230. With some skill you can replace the part without removing the ignition switch from the column. We've replaced more than a few. If you need any assistance let us know.
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Constant Audible / Ignition issue--AHHH! minch77 Defender Technical Discussions 14 April 30th, 2012 11:20 AM
Article from the September 2004 Issue of LRE norros Misc. Chit-Chat 8 September 16th, 2004 02:13 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
Private Messaging "Read Reciept" issue? chrisvonc Support & Suggestions 0 May 23rd, 2004 08:51 AM
