Ignition Help - Defender Source
Old May 19th, 2015, 02:41 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Ignition Help
This might be a long shot but I am looking for some sort of diagram/cut away of the ignition switch on my D90. I have had the worst time getting the two screws that hold the switch in place out and disassembled the switch in order to get it out. I've replaced this switch before and have taken apart these Lucas switches and put them back together. This time I'm wondering where this tiny spring and tooth inside the switch go? Please see pics. Thanks in advance.
Name:	Lucas Ignition Switch inside.jpg
ID:	121182   Click image for larger version
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
Ignition help beck427 Defender Technical Discussions 1 November 2nd, 2006 02:09 PM
Need HELP Bad!!!!- Ignition and Rotor Problems Doug Young Defender Technical Discussions 0 June 10th, 2004 11:32 PM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
