Ignition Coil Wire Set recommendations - Defender Source
Old September 13th, 2011, 08:54 AM
jijalicious
Jiman Khosravan
'94 D90
Question Ignition Coil Wire Set recommendations
Morning,
I tried to search what people use for ugprades/replacements... but couldn't conclude anything for wire set:
Rover north has the LRN genuine for $70
http://www.roversnorth.com/store/p-6...-39-litre.aspx
and AB has a bunch of them... from $43 to $145
http://www.roverparts.com/Nxt/search...ield=Price:ASC
Then Bosch also has a set for like $40
http://cgi.ebay.com/ebaymotors/Bosch...item43a922fe8d
Pros or Cons for any of them?
~Jij
Old September 13th, 2011, 09:06 AM
The Dro
Dro
1988 Ninety
Jiman
I've been using these for the longest (others here too).
http://www.kingsbornewires.com/categ...?categoryId=38
Old September 13th, 2011, 09:49 AM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I just replaced wires and plugs on my 97 this past weekend. I also used the (8mm) Kingsborne wires recommended by Pedro above. I am very pleased. Good price, high quality and fast service.
Old September 13th, 2011, 10:43 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Running with above as well for last year.....
Old September 13th, 2011, 12:15 PM
jijalicious
Jiman Khosravan
'94 D90
$33 and recommended by peers? Can't beat that! 8mm RED comming up right up!
~Jij
Old September 13th, 2011, 12:29 PM
The Dro
Dro
1988 Ninety
~Jij
Old September 13th, 2011, 12:41 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Don't skimp on the wires...Magnacore and never have to do them again.
Old September 14th, 2011, 09:57 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am running magnacore in 2 of my vehicles--paid around $100 if I remember correct. They work great, but no seat-of-the-pants difference in power between these or any other wire. My last set of wire was a cut-it-yourself Excel set and it has been working great as well. Next set? Kingsborne--that is a great price, especially for 8mm.
I have been and remain a fan of magnacore, but at 3x the cost, I won't buy them again. With all the "hype" around them, I have not noticed any difference in performance in my 2000 DII, 88RRC or 94 D90(4.6). Quanlity? Yep, fantastic. Strictly a price decision.
Old September 14th, 2011, 07:09 PM
I have some magnecors and cut to fit Morosos, I will be doing the morosos again as they are a little cleaner to install
Old September 15th, 2011, 08:05 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
8mm can be annoying to get in to the stock 7mm separators so when ordering from Kingsborne it's a good idea to order a set of the separators at the same time.
I've been using Kingsborne for around 25 years, though I did try Magnecore (nothing wrong with them other than price) and even, gasp, some roll yer own. But went back to Kingsborne.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 15th, 2011, 08:38 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Unless you have an engine with a hot ignition, lots of advance, and high compression you really won't see any benefit between a good set of ignition wires and a really good ( and much more $) set.
What will be beneficial is proper wire looms to keep the wires seperate and away from ground material. That goes for where they go into the dist. cap as well, keep them from overlapping.
Old September 15th, 2011, 09:06 AM
jijalicious
Jiman Khosravan
'94 D90
If ONLY you had said that 3 days ago!
Too late... order's coming in already :/
Guess gotta go see if local car part store has some.
~Jij
Old September 15th, 2011, 10:48 AM
jefferson's Avatar
jefferson
Jeff A
Jiman - Tom is right. Getting the 8mm wires into the stock seperators can be difficult. On my truck it worked OK, but I did use some 8mm seperators from Kingsborne in a few spots in my routing to tidy things up. I have a bunch leftover. You are nearby - they are yours if you would like them. Let me know. Jeff.
jijalicious
Jiman Khosravan
'94 D90
Sending PM!
Old May 29th, 2012, 09:33 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So I think I'll try the 8mm Kingsbornes over the Magnecors. I noticed that some of the factory wire separators are attached to the valve covers, and it appears the Kingsborne wire separators don't have the ability to attach to an anchor point. Anyone have insight on to cleanly mount 8mm wires without leaving those factory wire separators unused?
Yes, I have OCD.
Old May 29th, 2012, 10:35 PM
Take them off go to the parts store and buy 8mm. Summit racing also has them
Old May 30th, 2012, 08:13 AM
Grover's Avatar
Grover
8mm MSD, and cut to size.
Old May 30th, 2012, 01:10 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Ok, so they are removable. It's time for new valve cover gaskets, so it should be a good time to pop those boys out and find some that fit the 8mm wires. Thanks.
coil, ignition wire set, part
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
