Ignition Coil question, when + side is charged, should the - side be charged as well? - Defender Source
Old November 22nd, 2010, 01:19 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Hey all, I need help and as always, is much appreciated. If the right side of the coil has 12 volts going to the +, should the - side be charged as well? I used my test lamp on my coil and when the ignition is turned to the 2nd position, not only the + side of the coil is charged but also the - side lights up as well. I know in Series distributors with points its only suppost to light up when the points open up but since this is electronic ignition, should both the + & - on the coil be sending juice to the ignition module when the keys in the 2nd position?
Robert Deniro
Old November 22nd, 2010, 05:47 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
The - side of the coil will show 12+ until the ign. module inside the dizzy sends out a - signal. That signal will tell the coil to fire upon engine revs. Works the same way as a points system. Points open, 12+ at the neg. side of coil. Points closed, 12- at the neg. side of coil.
1963/2008 Defender Crew Cab
1965/1997 FJ45 Pick up
Old November 23rd, 2010, 03:54 PM
Neil McCauley
Neil McCauley
Thanks!
Robert Deniro
coil
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
Side Step question 48vphantom Defender Technical Discussions 10 January 17th, 2007 09:17 PM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
