Ignition Coil for 3.9L V8 - Defender Source
Old September 27th, 2015, 08:41 AM
Grover's Avatar
Grover
Question Ignition Coil for 3.9L V8
Ok, I've been chasing a warm starting problem and upon changing the spark plugs, I noticed oil leaking from my ignition coil.
The coil was bought from AB back in 2011, it only has about 5k miles on it. I would think it would last longer than just a few years. This coil is a Bosch and it has 0221 122 392 stamped on it.
Now I've read other posts and other owners are using Bosch 00113.
Are both appropriate for this engine?
AB also sells a Lucus coil for this engine for $39
Any advise on which coil to use?
This is for a NAS D90 with a 3.9L V8
Cheers...
Old September 27th, 2015, 09:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Grover View Post
Ok, I've been chasing a warm starting problem and upon changing the spark plugs, I noticed oil leaking from my ignition coil. The coil was bought from AB back in 2011, it only has about 5k miles on it. I would think it would last longer than just a few years. This coil is a Bosch and it has 0221 122 392 stamped on it. Now I've read other posts and other owners are using Bosch 00113. Are both appropriate for this engine? AB also sells a Lucus coil for this engine for $39 Any advise on which coil to use? This is for a NAS D90 with a 3.9L V8 Cheers...
Mike, my money is on the first sentence of your second paragraph. 5k miles since 2011. If I'm reading that correctly I would say drive, drive, drive and the problem is likely to resolve itself. How old is the fuel filter? When they sit for long periods of time they can get crusty and breakdown inside.
Clay
Old September 27th, 2015, 10:44 AM
oil leaking from a coil is a problem.
Old September 27th, 2015, 11:07 AM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Yes, oil leaking from the coil means a bad coil. My first bad coil had a black tar'y substance oozing from the top.
For whatever reason, I have replaced three coils in my NAS 110 in the 10 years I have owned it. Have never gotten insight as to why. Could blame high under bonnet temps here in So Cal, I guess.
In the most recent occurrence, the truck stopped dead and despite turning over strongly wouldn't start. This is with a Mallory distributor.
I now keep a spare.
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old September 27th, 2015, 11:23 AM
Grover's Avatar
Grover
What brand is recommended? Part number?
Old September 27th, 2015, 11:58 AM
the Bosch one.
Old September 27th, 2015, 08:26 PM
Use the good Bosch one not the cheapie, I had one of those fail within 1k miles for new
95' D90 - daily driver..
Old September 28th, 2015, 07:55 PM
Grover's Avatar
Grover
Question
Ok, Bosch is the ticket!
Now I'm confused on which one:
00113
Or
0221122392
Is 00113 a newer version of 0221122392?
For those of you who just bough a Bosch coil, what part number is it?
Cheers...
Old September 28th, 2015, 08:29 PM
http://www.defendersource.com/forum/...ighlight=bosch
coil, v8
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
Who is the ignition module / pickup coil authority here? dnp Defender Technical Discussions 30 August 22nd, 2008 03:14 PM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Ignition/coil to EUC Mike Hippert Defender Technical Discussions 6 March 7th, 2005 02:36 PM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
