Coil/Ignition Wiring?
Maybe a dumb question but.....
NAS D110 - Lucas block box right next to but behind the coil near the fender - not sure what this is (need to get a pic) - thought it was ignition amplifier but don't think thats it.
There are two heavy gauge battery cables going out the bottom of that box that route into battery box under seat. Solid Brown wire goes to + terminal on battery (makes sense). The Brown/White cable goes to the top post on the side of the battery box (which is also labeled + positive terminal). There is nothing else connected there either inside the battery box or on the other side of that screw.
I am trying to figure what that brown/white wire does and what is that post for on the seat box?
