Idler pulley seized, snapping fan belt - Defender Source
Old October 1st, 2016, 09:25 AM
50thd90
50th
1998 50th D90
Fun times! Wondering if the same pulley is used in the 4.0 p38 engine as my defender 90 50th?
Old October 1st, 2016, 11:05 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Remove snap ring, press out old bearing and press in new. Replace snap ring. Less than 10 dollars.
------ Follow up post added October 1st, 2016 10:07 AM ------
Snap ring can be difficult. I drilled a small groove adjacent to ring to be able to lever it out. Just need enough room for a strong pick. Socket And vise is enough to push in and out. I used the old bearing to press in the new one. The bearing used is pretty universal and a short search will find the part number
Old October 4th, 2016, 12:43 AM
50thd90
50th
1998 50th D90
Can't find the exact number. Seems to be for disco 2 and p38??
Old October 4th, 2016, 01:08 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Skf 6203 2rs
Most part stores stock it.
Old October 4th, 2016, 10:02 AM
50thd90
50th
1998 50th D90
Thanks! Any part number for the fan belt ?
Old October 4th, 2016, 04:12 PM
50thd90
50th
1998 50th D90
They want $62 for the belt, can this be true?
fan, idle, pulley
200tdi Timing Cover Idler Pulley DailyDrivenDefende Defender Technical Discussions 3 March 19th, 2016 06:26 PM
Water pump idler pulley bearing 671rover Defender Technical Discussions 2 February 9th, 2016 08:01 PM
3.9L idler pulley bearing Grover Defender Technical Discussions 2 November 12th, 2015 12:31 PM
idler pulley bearing 300TDI lrna04 Defender Technical Discussions 12 November 18th, 2013 04:19 PM
Axle snapping Physics nikojo Defender Technical Discussions 5 November 30th, 2008 01:11 PM
