idler pulley bearing 300TDI - Defender Source
Old November 13th, 2013, 04:49 PM
lrna04's Avatar
lrna04
Michael
1994 D90
I am trying to find a part number or size for the idler pulley bearing on my 300TDI. Any help is appreciated, thanks.
Name:	idler pulley bearing.jpg
Old November 13th, 2013, 04:57 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Try Nachi p/n 6203-2NSE9. World Pack P/N 9-00090-679-0.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 13th, 2013, 04:58 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
I was looking for this info myself. Thanks Rob!
Old November 13th, 2013, 05:53 PM
My local NAPA had them in stock.
Have fun with the snap ring.
Old November 14th, 2013, 09:30 AM
lrna04's Avatar
lrna04
Michael
1994 D90
Thanks for the info, just what I was looking for. I will try Napa today. regards the snap ring removal I am the drilling a small hole in the idler pulley, see the attached pic.
Name:	idler pulley mod for snap ring.jpg
Old November 14th, 2013, 10:41 AM
That's pretty clever. I've always just used pocket screwdrivers and a bunch of cussing.
Old November 14th, 2013, 05:49 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Helpful link:
http://www.reedx.net/landrover/maint/tensioner/
Cheers
- Charles Eames
Old November 14th, 2013, 10:44 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I've developed a slight chirp which I believe is coming from this pulley. Usually gets a little more pronounced when engine is at operating temp. I've looked into the penny trick shimming the pulley to stop the chirp. Sounds kind of clever but not a long term solution.
http://www.landyzone.co.uk/lz/f38/30...ick-64595.html
Two questions:
Is it dangerous to drive with this "condition"? It's minimal but kind of annoying.
Should I even attempt to do the penny trick or just replace the whole shebang? I've read that in some cases of replacement, the chirping comes back after a few hundred miles.
Thanks for any input
Old November 15th, 2013, 05:24 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
do what you want but there is no right way to do a wrong thing.
------ Follow up post added November 15th, 2013 05:30 AM ------
I only say that as I have witnessed several denial cases where this is concerned (idler bearing, both V8's and tdis) that have failed catastrophically and owner looking at a very large bill to repair hoses, fans, and even radiators……..in stead of a very small one to fix the tensioner.
…..pulley falls off. hits fan, breaks fan, fan takes out oil cooler line, car catches fire, pulley goes into radiator…..but the car IS on fire so at that point who cares about the dents in the bonnet that are from the fan parts hitting the inside…..
actual story.
Matt Browne
Old November 18th, 2013, 10:50 AM
Naplm00
Matthew
6203 bearing is very very common. I have a few new ones sitting on my shelf, I use them for rebuilding moped engines.
I would not drill a hole to remove the snap ring, it weakens the pulley. Just use a shim or stiff feeler to get under it and pry it out with a small screwdriver.
If you want to take a trip, I can press in the bearing for you. Ive got a press in my garage for this exact reason, and just did the two idlers on my 351W in my F150. They use the same bearing btw
Old November 18th, 2013, 11:02 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
I have a brand new Dayco 300tdi idler pulley assembly if you're interested. PM me or email jrose609@msn.com
Old November 18th, 2013, 11:44 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
After much cussing (as above) I got the snap ring out. I then ground a notch in the end to make it easier the next time. There's a thread in this forum where we discussed carefully peeling back the seal of the bearing and inserting more grease into the bearing. Be careful pressing in the new one and make sure you only press on the outside race of the bearing. Oiling it helps.
Old November 18th, 2013, 04:19 PM
lrna04's Avatar
lrna04
Michael
1994 D90
I finished the job this weekend and endedup welding a scrap to the ring... and wa la out it came. I also replaced the old ring with a new e-clip.
Name:	bearing pic 1.JPG
ID:	84525   Click image for larger version
Name:	bearing pic 2.JPG
300tdi, idle, pulley, tdi
300TDI serpentine belt tensioner bearing R&R Viton Defender Technical Discussions 3 August 31st, 2011 09:15 PM
tensioner pulley bearing floatflyer Defender Technical Discussions 7 February 1st, 2010 08:54 AM
'97 Serp Idler Monkeyboy Defender Technical Discussions 4 May 15th, 2009 01:39 PM
300tdi pilot bearing Ren Ching Defender Technical Discussions 3 May 28th, 2008 05:39 PM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
