Idle speed Vibrations - Defender Source
Old January 29th, 2011, 02:32 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
G'day,
I search the forum and couldn't find anything on vibrations at idle speed. My 110 200tdi vibrates at idle speed more then I can stand. It shakes every plastic bits of the dash, enough to loosen the screw and shake everything around. If I touch the fun pedal a bit so the rpm goes +/- 100 more it feel more civilize. the idle speed is about (ear setting) 600-700rpm. I checked the engine mounts as well as tranny and t-case. They're new and well bolted. I know they're agricultural type of diesel but is there a cure?
Jeff
Old January 29th, 2011, 03:02 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Try raising idle 100rpm or so.
Old January 29th, 2011, 03:08 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
It might be a bit too much? What's the normal idle speed for a defender 200tdi?
Old January 29th, 2011, 03:10 PM
ajh
Andrew J. Hutton
I find 800rpm or so good, diesels smooth out as rpm increase in general, too low and they shake like mad.
Old January 29th, 2011, 03:15 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
If I want to fit an rpm gauge (I have an old smith outta mini) once I have the wire coming out of the alternator, do I need to ground the gauge? I'm thinking about using the gauge to know the actual rpm setting.
Of course I do.. I just thought about it for a second. I might be a bit tired! I'll set up the gauge and try to get it to 800rpm. Do you know the factory setting? Is it 800rpm ?
Old January 29th, 2011, 03:24 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
mine does the same thing, I just haven't had time to turn up the idle a bit
Old January 29th, 2011, 04:03 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
The adjustment for idle speed ain't the throttle cable? Is it? There must be a screw of some kind? Can anyone tell me which one is it?
Thanks lads!
Old January 29th, 2011, 05:41 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
check on doug's site...
Old January 29th, 2011, 06:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I have the same issue. Mine vibrates like hell at 700rpm, and a simple increase to 800rpm clears it up.
Semper Fi!
Old January 29th, 2011, 08:05 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Where's at?
Old January 29th, 2011, 08:10 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
http://www.dividingcreekroverimports...o_from_the_web
buried in here...there's a paragraph on idle adjustment
Old January 29th, 2011, 08:16 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Thanks! I'll get you the result tomorrow..
idle
idle speed adjustment FlaD90 Defender Technical Discussions 15 July 23rd, 2012 12:32 PM
Idle Speed kennybahr Defender Technical Discussions 4 November 23rd, 2008 10:15 PM
1997 D-90 Idle Speed ndhlp Defender Technical Discussions 4 October 11th, 2006 11:43 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
