Idle Speed - Defender Source
Old November 23rd, 2008, 05:12 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
Idle Speed
I've started to notice when I start my 94 90 it idles at about 1500-2300 Rpm for a couple of seconds...then it goes down to normal, it's never done that before. Also when I shift, it idles at 1200 Rpm for a few seconds too...then it goes down to normal. Can anyone help me figure out what might be happening?
Kenny
Old November 23rd, 2008, 06:30 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Unplug the battery or ECU lately?
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 23rd, 2008, 10:06 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
No I have not unhooked the battery or the ECU, should I?
Old November 23rd, 2008, 10:09 PM
Hans's Avatar
Hans
Hans Haase
Well, the symptoms you are describing are actually kinda normal to me. The ECU does increase the idle speed in certain situations to prevent stalling. But it can be more pronounced if your ECU has recently lost power and has to re-learn the idle curves.
It may also be a vacuum leak somewhere that has recently cropped up, and the stepper motor hasn't adjusted to it yet.
-Hans
My oil line fix
Old November 23rd, 2008, 10:15 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
-Hans
Hans, thank you for the quick reply! So with the above stated, everything should be probably be OK once the ECU relearns the idle cure?
Kenny
idle
idle speed adjustment FlaD90 Defender Technical Discussions 15 July 23rd, 2012 12:32 PM
1997 D-90 Idle Speed ndhlp Defender Technical Discussions 4 October 11th, 2006 11:43 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
