Idle problem - Throttle position sensor? - Page 2 - Defender Source
Old January 7th, 2008, 11:45 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Joe,
If you want to get a more accurate base idle adjustment then you need to disconnect the stepper motor and plug the idle air bypass. I did a write-up here: http://www.defendersource.com/forum/...8&postcount=30
Also, Hans has good advice about the fuel & ECU relays: Just replace them if you don't know how old they are. I think they get corroded over time. They're in the passenger footwell, next to the ECU. The two relays are the same.
idle, sensor
Throttle Position Sensor Source?? rgrrvr Defender Technical Discussions 34 April 10th, 2013 09:56 PM
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Idle problem - need advice fleabus Defender Technical Discussions 24 February 7th, 2006 06:36 PM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
