Idle problem - need advice - Defender Source
Old December 1st, 2005, 06:18 PM
fleabus's Avatar
fleabus
Dan
None :(
Unhappy Idle problem - need advice
When the truck is cold it starts fine and idles and drives normally.
Once the engine warms up after driving around a bit the idle drops and the engine will stall unless I keep the rpm above 1K. If I let it die, then try to start it... it will start up fine, rev to 1K then die. Rinse and repeat until engine cools down.
Not sure if this is coincidence or not, but it started to snow today for the first time this season. Temperatures in the low 30s.
Fuses are fine... Any ideas?
-Dan
Old December 1st, 2005, 06:50 PM
Hmm, on a 97. Is the ECU throwing any codes? Anyone near by with a code reader?
Old December 1st, 2005, 07:46 PM
fleabus's Avatar
fleabus
Dan
None :(
THe local shop let me borrow their reader and here is what I got:
P3999 and P0430
From the thread below it appears that these may be bogus.
http://www.defendersource.com/forum/...ighlight=P3999
-Dan
Old December 1st, 2005, 08:29 PM
Hmm, ok have you tried cleaning the IAC? Sometimes the end gets dirty and needs to be cleaned up to work correctly.
Old December 1st, 2005, 09:05 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds like an issue when it goes into closed-loop, and starts accepting input from other sensors. I'd start throwing an ohm meter onto things like the MAF sensor and TPS sensor. Those would be the culprits I would suggest first. Maybe also check the crank sensor too.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 1st, 2005, 09:14 PM
fleabus's Avatar
fleabus
Dan
None :(
Where is the IAC on the 4.0? It is not where I expected it to be...
http://www.defendersource.com/forum/...achmentid=4038
Old December 1st, 2005, 09:52 PM
Hans's Avatar
Hans
Hans Haase
Never worked on a 4.0, but from the limited info I could find real quick on the net, also check the side of the throttle body. Either way, it has to be somewhere on that upper manifold area.
-Hans
My oil line fix
Old December 1st, 2005, 10:18 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Dan, i'm in the Redmond area. 97 D90 also. If you can get over here I'd be happy to offer a second opinion or help. How many miles on the rig?? Send me a pm if you want
jeff
Old December 2nd, 2005, 01:29 PM
fleabus's Avatar
fleabus
Dan
None :(
Ok, so I found the IAC and cleaned the bugger.... now the idle is way too high
Maybe time for a new stepper motor?
-Dan
Old December 2nd, 2005, 01:46 PM
Try reseting the ECU, it may need to relearn the stepper now that it is clean.
Old December 2nd, 2005, 02:00 PM
fleabus's Avatar
fleabus
Dan
None :(
To reset, simply disconnect battery?
-Dan
Old December 2nd, 2005, 02:21 PM
I am not 100% sure on a 97? I think if you disconnect the ECU for 5 minutes or so that should do the trick.
Old December 2nd, 2005, 02:33 PM
fleabus's Avatar
fleabus
Dan
None :(
Ok... ECU reset and idle is back in normal range, but the problem persists
-Dan
Old December 2nd, 2005, 03:02 PM
Check for any vacuum leaks, they don't have to be big to screw things up.
fleabus's Avatar
fleabus
Dan
None :(
Does anyone know if NAPA part # 2-1738 (stepper motor) is only for pre-97 models?
-Dan
Old December 2nd, 2005, 09:57 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Dan, that number(2-1738) is for the 94-95 3.9L engine. The one for the '97 from Napa is CRB21856 $43.49. The brand is Echlin...
Here's the link:
http://napaonline.com/masterpages/NO...+Control+Valve
jeff
Old December 2nd, 2005, 11:27 PM
Hans's Avatar
Hans
Hans Haase
Wow, looks almost exactly like the one on my Jeep too!
-Hans
My oil line fix
Old December 3rd, 2005, 01:54 AM
fleabus's Avatar
fleabus
Dan
None :(
Here's the link:
jeff
Thanks Jeff!
Old December 3rd, 2005, 09:31 AM
cpk
Corey K-nig
1993 NAS Defender 110
Check the fuel pressure regulator. I had a problem with idle that lead to the engine dieing then it wouldn't start. Cleaned the fuel pressure reg. with WD40 it's been fine since.
Old December 6th, 2005, 01:17 PM
fleabus's Avatar
fleabus
Dan
None :(
FOLLOW UP: The problem turned out to be a bad throttle position sensor.
All better now
-Dan
idle
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
97 Idle Problem gtg067i Defender Technical Discussions 2 January 8th, 2007 09:28 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
