Idle problem - need advice - Page 2 - Defender Source
Old January 2nd, 2006, 09:13 PM
fleabus's Avatar
fleabus
Dan
None :(
Bringing this thread back to life...
The problem turned out not to be the TPS or ECU since I replaced both and the problem has resurfaced. It seems as though swapping out the ECU helped for a week or so, but now the problem is back
I am replacing the stepper motor tomorrow. Where do I find the fuel pressure regulator on my 97? Someone mentioned cleaning the bugger might help?
Thanks.
-Dan
Old January 17th, 2006, 06:57 PM
Cholla
Jack Copass
97 D-90 SW
Hey Fleabus, did you get your 97 fixed? I am having same problem, on my 97. The fuel pressure regulator is on the right rear of fuel rail below the right rear corner of plenum, with a short vacuum line running to it from the plenum. I am replacing this regulator also, as it is suspect only delivering 28 psi at at idle, 30 at 2500 rpm, but full line pressure of 38 psi with vacuum disconnected. Watching the fuel pressure gauge at idle, sometimes it will drop to 22-24psi if idle drops to 200-400 rpm. This may be a contributing factor. I have done the same things you have also.
Thanks, Jack
Old January 17th, 2006, 07:51 PM
fleabus's Avatar
fleabus
Dan
None :(
Thanks, Jack
Jack-
I haven't fixed it yet, because the problem only seems to happen intermittently (chasing ghosts). Replacing the stepper motor made no difference either. Please let me know if a new fuel pressure regulator helps any.
-Dan
Old January 17th, 2006, 08:48 PM
Cholla
Jack Copass
97 D-90 SW
Originally Posted by fleabus
Jack-
-Dan
Dan, I will let you know what happens in a day or two. It was intermittent for me also, but now almost every day, suddenly dropping way low or stalling. I took out my new (2months old) stepper today, and installed my old one. Intermittent drop in idle remains. I read somewhere if the TPS reads below 13%, our Gems system cannot control idle well. However, I don't know how to test this sensor. Maybe one of our compatriots on this board will have the procedure?? Also, I am going to try changing the MAF (Mass Air Flow sensor) with a known good-working one to see if that's it.
Thanks, Jack
Old February 7th, 2006, 06:36 PM
Cholla
Jack Copass
97 D-90 SW
Smile Poor idle resolved!
Jack-
-Dan
Hello Dan, I changed my fuel pressure regulator, w/improved pressure to specs now, but no change in idle problem. Also installed a new multi-function relay module (black one behind ECU) which powers up MAF, Fuel injectors and pump. No change. After checking my suspect TPS with a digital multimeter, I found the resistance range from 50-106 Ohms at throttle closed position to 3.29K Ohms throttle fully open. The reading was moving up/down constantly at closed position, so I replaced TPS. Then with the new one, Idle immediately up to 2K rpm on starting, then after driving some always about 1K to 1.5K rpm. I learned the Gems computer can reset the "Adaptive variables" with a few days or more of driving, but after a week without much improvement, I went to LR dealer and had the adaptive variables reset by LR Testbook computer, as well as the base idle. Knock on wood, It is working fine now! My old TPS would only cause problem when throttle released, and intermittently. Many thanks to Rob Dassler, Mike Hippert, and Nick Markiw for their expertise in figuring this out!
I hope this info may be of some help, Jack
idle
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
97 Idle Problem gtg067i Defender Technical Discussions 2 January 8th, 2007 09:28 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
