Idle Oil Pressure? - Defender Source
Old March 24th, 2007, 07:43 AM
bomilcar's Avatar
bomilcar
Stephen Miller
73 Series III Orig Owner
Idle Oil Pressure?
I just put in a ISSPRO electric oil pressure gauge. What pressure should I see at idle? I find in the book it should be 28psi at 2000rpm but I can not find an idle number.
On a different issue. Has anyone replaced the AC pusher fan with an upgraded version? Not much room for larger but anyone try?
Steve
73 Series III (Original Owner)
94 D-90
2011 LR4
"anything that can go wrong has"
Old March 24th, 2007, 12:19 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
28psi at 2000rpm? Excellent, I thought mine was low.
Mine idles at around 15psi or so.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 24th, 2007, 01:48 PM
mffoster
Mike Foster
94 D90, 2007 Supercharged RR
Oil Pressure at Idle
The oil pressure on these things is almost scarily low. I believe that my factory manual basically called out slightly more than 10 psi per 1000rpm. At idle you should be between 10 and 15 psi. I've had a 94 since new, and put in VDO guages within about 6 months of the purchase. I was pretty nervous originally, but that just seems to be the way these work, and your's sounds fine. You can get a bit more pressure if you take off the sandwich plate to the oil filter and use a carbide to open up and smooth the machined passages. Also, if you switch to something like a Mocal adapter plate with a thermostat to bypass the oil cooler when cold you'll see pressure on the guage much more quickly on a cold start.
If you're really interested I could go look up the exact pressure specs in the factory manual.
Regards,
Mike F
Concord, NH
Old March 24th, 2007, 11:27 PM
bomilcar's Avatar
bomilcar
Stephen Miller
Thanks guys. Changed oil and filter; 20 50 with a K&N filter and I am getting 30+ psi at 2000 rpm and right arount 10 at idle 750rpm. 10 gives me pause but I guess it is OK. Sure is higher after I dumped the syntec and put in the 20 50. Wha tis going to be interesting is in the heat of the summer 100+ degrees.
Steve
94 D-90
2011 LR4
Old March 25th, 2007, 01:10 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Wouldn't changing the bypass spring to a higher weight spring force the pressure up by not allowing oil to bypass the circuit? I am also curious.
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old March 25th, 2007, 09:03 AM
robisonservice
John Robison
2008 Supercharged Range Rover
The idle oil pressure is very much dependent upon the combination of bearing wear and oil viscosity. An older motor with Mobil 1 0-40 might have 2-5psi at idle. The same motor, with dino 20-50, might have 10-12 psi.
When 0-40 oil was introduced in 1998, Mercedes had to drop the oil pressure gauges from its cars because the low numbers people saw at idle scared them, and caused service problems.
idle
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
