Identifying my gearbox.... - Defender Source
Old August 25th, 2011, 01:28 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Hey guys,
I have a '94 D90 #1500 which is having some issues. It doesn't shift into 2nd and 3rd very smoothly especially when it's cold, and there seems to be a lot of slop in the drive train. A while back, I put new u-joints in the prop shafts and just for the heck of it, I drove it around the block with front shaft off to see if the slop got better. It actually got much worse. Don't know what, if anything, that says.
I heard that that slop can develop in the tfer case from leaving the diff lock engaged for longer periods of time that when you actually need it engaged. Like driving around on the trail all day with it engaged. Don't know how true that is.
So anyway, I want to fix these issues, but need to ID my gearbox. I can take it to a tranny place in my area to have them go through the box and case, or should I just get new rebuilt? Advice?
Pete
Pete
Old August 25th, 2011, 03:15 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Pete,
The easy way to tell is the Shift pattern,
If reverse is next to 1st gear then you have an Lt77
The R380 has reverse on bottom right corner
Old August 25th, 2011, 03:52 PM
peachyracer
Peter Stolz
R380 it is, then! Thanks!
Pete
Sanity check after replacing steering gearbox cgalpin Defender Technical Discussions 5 January 14th, 2008 06:39 AM
I've broken my gearbox!!! mikeslandrover Defender Technical Discussions 6 May 29th, 2006 05:04 PM
gearbox help !! mud_man Defender Technical Discussions 12 November 28th, 2005 12:29 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
