Identify transmission - Defender Source
Old January 16th, 2018, 07:03 PM
Tadel001
Tim Adelman
Can you help identify this transmission. I know it is an LT77 but trying to figure out if it is a late model.
ID:	346489   Click image for larger version
Old January 16th, 2018, 07:20 PM
Defender V8 box. Not sure the age as the suffix seems to be missing.
Old January 16th, 2018, 07:35 PM
Chris B
72 + D1 drivetrain =?
Its a 61A See Ashcroft's site
The manual boxes can be catagorised as "Long Stick" as fitted to the Defender and "Short Stick" as fitted to the Disco.
If your serial number starts with any of the following then you have a longstick : 50A, 51A, 52A, 56A, 60A, 61A.
If your serial number starts with any of the following then you have a shortstick : 53A, 54A, 55A, 57A, 59A, 63A.
The longstick boxes come with the top casting that the gearlever and turret bolt to but you will need to remove the following from the old unit : the bellhousing and dowels, transfer case dowels, gearlever and turret and diff lock pivot bolt if fitted.
The shortstick boxes come with remote top assembly with reverse switch fitted but you will need to swap over the bellhousing & dowels, transfer case dowels, extension gearstick and diff lock pivot bolt.
Old January 16th, 2018, 08:19 PM
Yah. 61A means is a Defender V8 box. The question is more the suffix. Looks like an "l" which would mean it is an R380, not an LT77. Take a picture from the side and it should be obvious which one it is.
Old January 16th, 2018, 08:27 PM
Tadel001
Tim Adelman
Yes, it is the suffix that is throwing me off. I was told is was an LT77 V8 that was overhauled by RDS into a diesel 4 cylinder set up.
Don’t have a full profile picture but will try to get one. I assume this pic isn’t helpful
Old January 16th, 2018, 08:33 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Does RDS normally stamp the gearbox, like Ashcroft and others, after a rebuild?
Decoded mine earlier today, H suffix, with a rebuilders stamp under the SN.
KGH - “Stinky LR diesel” Defender Snob
Old January 16th, 2018, 09:01 PM
A side picture from the right side will make it obvious. The box vents are in different locations is the easiest way to tell.
Old January 16th, 2018, 09:10 PM
LT77 on left, R380 on right. One is Disco, one Defneder. Ignore that... Note location of red plugs for vent lines.
Old January 16th, 2018, 09:51 PM
Tadel001
Tim Adelman
So I currently have a t9A suffix E I the truck with a 2.5td. The 61A is available to install. As I read the gear ratio (Land Rover Gear FAQ), the LT77 suffix E has more acceleration (if there is such a thing with a 2.5td) than the 61A but the 61A has more top end speed. For those understanding the gear ratio does that seem right?
Old January 16th, 2018, 10:05 PM
The suffix is only to do with strength of parts. The prefix sets the gear ratios. But you said it was rebuilt with different gears. It could have anything in there. Some of the gearing can be mixed and matched. You would need to measure or ask the person that built it.
How to identify an R380 transmission? cellulararrest Defender Technical Discussions 12 July 26th, 2006 12:02 PM
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
