Identify this part? - Defender Source
Old May 6th, 2015, 10:18 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Identify this part?
Got this steering setup many years ago from a buddy. Everything fits perfect less the steering damper. The damper is either too long or the mount won't fit on the rod.
ID:	120145   Click image for larger version
Old May 6th, 2015, 10:20 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Heavy duty steering components are usually a larger diameter... You need another damper mount to fit the larger diameter rod..
Was the damper part of the "kit"?
Was it originally off a disco?
Old May 6th, 2015, 10:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I don't see a photo of the other side of the dampener, but d1 dampers are stud-stud, so it's not a d1 dampener.
Can you you get the part number off the dampener or shoot a photo of the other side/mount?
Old May 6th, 2015, 10:38 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Originally Posted by Z.G View Post
I don't see a photo of the other side of the dampener, but d1 dampers are stud-stud, so it's not a d1 dampener. Can you you get the part number off the dampener or shoot a photo of the other side/mount?
Correct. But they often move their steering dampeners and use a kit to do so... Thought it might be part of that kit (some kits switch to loop style)
Old May 6th, 2015, 10:47 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
That's an RTE setup, but I can't really understand what your issue is. What am I missing here?
It looks like you need to flip the bracket around to offset the clamp inward slightly, then compress the dampener a hair to get the clamp lined up and pinched down.
-Ash
Geared Restoration Co.
352-572-3236
Old May 6th, 2015, 10:57 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Ash from the pic it looks like the damper mount won't fit on the larger steering rod. I have the same setup and switched to a larger mount. Also switched to disco style steering but that's another story.
Old May 6th, 2015, 11:10 PM
Ash's Avatar
Ash
Ash Heller
Is that what's going on? My eyes aren't working.
Yeah, if that's the case just give Bill at RTE a call and have him send you a new clamp. He makes one for the stock 0.875" drag link, which is likely what you have there, and one for the 1.25" link that's on your truck.
-Ash
352-572-3236
Old May 7th, 2015, 08:21 AM
97-D90-736
Nick Vogel
Sorry guys for making a vague post. The mount itself fits perfectly. The problem I am having is that when I mount it and try to turn the wheel right, it binds and will only let the tire turn a small amount. It doesn't appear to be the issue when turning left. I am going to see if Bill's webpage has any pictures of it mounted to help me out.
Old May 7th, 2015, 09:11 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Can you post a photo of where the stabilizer is mounted on the chassis side? I think that may answer your question
Old May 7th, 2015, 09:57 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Have centered the damper with the wheels straight ahead? Your picture shows the wheel cranked to the right?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 7th, 2015, 10:05 AM
97-D90-736
Nick Vogel
I sure can when I get home tonight. Based on the responses, I went to RTE's webpage. I have the steering stabilizer mounted to the original hole but there kit has it relocated down.
http://www.rte-fab.com/products?page...category_id=16
The only thing that I am missing is the bar to lower the frame mounted side (which is now starting to make a ton of sense).
Old May 7th, 2015, 11:43 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Check this out--I just put my old RoverTym damper back on this truck.
Bought from Steve in 2003 when it was still RoverTym.
You can see the frame end bracket position...
Rent my
Old May 7th, 2015, 12:15 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I wonder if OP is trying to mount the bracket on the inside of the frame, that'd be my guess.
Old May 8th, 2015, 09:58 AM
97-D90-736
Nick Vogel
Thanks for the help guys. I talked with Bill at RTE and confirmed that without the frame extension, it would bind up. He is making one up for me. Considering I got 95% of the kit for free, I am willing to spring the couple of bucks for the arm.
Old May 8th, 2015, 11:00 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Better pic- I meant to post this one of the bracket the other day...
Rent my
Old May 8th, 2015, 12:06 PM
The other option is to get the factory steering drop arm side end with the bracket cast into it and then it would all be fine.
Help Identify Part steinhnj Series Technical Discussions 2 June 27th, 2011 12:49 PM
Identify this part Manimal Defender Technical Discussions 1 January 12th, 2010 02:53 AM
How to identify an R380 transmission? cellulararrest Defender Technical Discussions 12 July 26th, 2006 12:02 PM
Let's play identify the tyre carrier... SYoung Defender Technical Discussions 6 May 9th, 2006 11:33 PM
Can someone identify this? Trigger Misc. Chit-Chat 16 March 30th, 2005 07:27 PM
