Identify This Leak - Page 3 - Defender Source
Old October 7th, 2009, 11:27 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
sorry...delete
Old October 7th, 2009, 11:45 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It may not look like much in the picture but it leaks quite a bit when heated up. It runs from that front area in the picture and forms drops on all the bolts on the inspection plate. It made it much easier to see where it was coming from once I cleaned it off. Is this location an easy disassembly or should I bust out my White Shepherd gunk?
Old October 8th, 2009, 08:14 AM
Carl, I'm not a fan of trying the additives. Either live with the leak or replace the seals. This is not an easy one. You need to remove the t-case and to be safe replace the input seal on the t-case and the output seal on the transmission (or you might be doing it again). Not expensive for parts but a lot of work. Or you can live with it :D
Old October 8th, 2009, 02:20 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by Manimal
The location of the leak in the picture above is that considered to be the joint between the main casing and the front output housing? Is it hard to fix?
That's a live with it leak because you've got to strip the box down to fix it, check any nuts on studs that hold the joint together are tight.
Don't think additives would work in that area because it's a paper type gasket not a seal.
Mike Hammond
Old October 8th, 2009, 02:52 PM
Wait, I am about 90% sure you can pull the front output assembly off without dropping the case. I have not done it, but I am about to as I need to install my part time kit and the directions say it can be done.
Old October 8th, 2009, 03:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
If you do, let me know!
I will tighten the bolts and see if it makes a difference.
Old October 8th, 2009, 03:42 PM
Ok, well I will do my best.
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
