Identify this Air Cleaner assembly - Defender Source
Old December 29th, 2014, 03:40 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
I've been trying to figure out what air cleaner housing this is. It looks similar to a 300TDi housing but the intake port seems to be different. The housing had a filter (NRC9238) installed and I installed a Defender 200TDi filter with no fitment issues (have not cranked over yet).
Thanks in advance
ID:	109645   Click image for larger version
Old December 29th, 2014, 06:17 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It's really hard to tell from the pictures, Andy, but is the pipe coming out the side modified with welded on metal pipe or is that black plastic or rubber jammed in the side pipe and sticking out at an angle?
That looks like a 300TDI air filter and hose to feed the inlet side of the turbo (with the exception of the extra piece mentioned above).
RDavisinVA
Old December 30th, 2014, 01:19 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
I forgot we had chatted about this via phone a few months back. I just pulled this unit out and I can now see the weld job on the end. Does look like the 300TDi filter housing photo's google came up with.
ID:	109762   Click image for larger version
Old December 30th, 2014, 01:40 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That sure looks like a modified 300TDI air filter housing.
RDavisinVA
assembly
K&N filter instead of stock air cleaner assembly melittle Defender Technical Discussions 2 November 1st, 2012 03:33 PM
WTB Range Rover air cleaner assembly ECR Wanted 5 November 1st, 2011 09:38 AM
200tdi Air Cleaner Assembly Wolf Fabrication Wanted 1 December 7th, 2009 11:32 AM
97 D90 air cleaner assembly RoverC For Sale - Parts 0 May 25th, 2009 02:54 PM
Wanted: Air Cleaner Assembly kiphartzell Wanted 2 September 15th, 2006 12:43 AM
