Identify Hose Below Potentionmeter - Defender Source
Old April 28th, 2012, 10:16 AM
jijalicious
Jiman Khosravan
'94 D90
Question Identify Hose Below Potentionmeter
Morning Everyone...
Went to get a haircut this morning.. pulled into the parking space and saw white smoke come out of the engine compartment...
After opening up the hood and looked below... liquid was spilling on the hot manifold and pipes causing the smoke...
Looked back from the top and saw this hose with a pin hole in it, and liquid flying out... (pics attached)
Touched the liquid.. it didn't' seem to be anti freeze, or oil... wasn't water.. a bit more viscous... or maybe it was one of them...
Any ideas what runs through this and what the hose is called to get it replaced?
~Jij
ID:	50837   Click image for larger version
Old April 28th, 2012, 10:27 AM
Just trace the other end and go to any auto parts store and buy a length. Might be emission control going to the carbon canister that prevents fuel tank vapor escaping.
Old April 28th, 2012, 10:43 AM
Grover's Avatar
Grover
Jiman,
That is #6 on your diagram.
This hose goes from the intake manifold to the a small water jacket under the throttle.
Check the hose clamps first, that may be the problem, if not, then just replace the hose. This can be bought at any auto parts store.
BTW, coolant runs through this hose...how old is your coolant?
Cheers...
Old April 28th, 2012, 10:58 AM
goes to the throttle body
Old April 28th, 2012, 01:12 PM
jijalicious
Jiman Khosravan
'94 D90
You guys nailed it nailed it nailed it...
I guess my eyes failed me earlier... I thought the coolant tank was full, but it was empty. The coolant had drained... and I guess when it was spilling out, that was the last drops that was very thin... so it didn't look as yellowish green as fresh coolant...
When I was removing the hose, it pretty much broke into 4 pieces... replaced it with identical cable from AutoZone, new clamps as well... We are good to go
Thanks all
~Jij
------ Follow up post added April 28th, 2012 01:14 PM ------
Oh and of course added coolant
And seems like tomorrow's mini project.. go back and buy new lines and replace a few other hoses...
~Jij
Old April 28th, 2012, 07:10 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
I recently replaced all the hoses with this kit from AB--it's worth the piece of mind to get them all done at once.
http://www.roverparts.com/Parts/9373A.cfm
Hose replacements kolvedic Defender Technical Discussions 1 March 14th, 2006 04:50 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
