Identifiy this part? - Defender Source
Old June 26th, 2007, 08:16 PM
pcscharfe
pcdefender
D90/NAS 110
Question Identifiy this part?
I found this floating loose in the battery compartment in my 97 D90 along with some tools left behind by the previous owner... It's likely garbage, but thought I would ask before before ditching it.
Thanks.
Paul
Old June 26th, 2007, 08:38 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
looks like the fill plug for your swivel balls
Kris
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
That there looks like the wading plug that goes into the bell housing. It's so water dosen't fark up your clutch/torque converter.
Neil
Robert Deniro
Old June 26th, 2007, 08:43 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Clutch housing plug and, in case of Tdi, timing chain compartment plug also.
- Charles Eames
Old June 26th, 2007, 08:44 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
It definitely belongs to the truck, I have a spare in each of mine. No idea where it goes.
Old June 26th, 2007, 09:53 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
wading plug, keep it
Old June 26th, 2007, 09:54 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
wading plug, not needed on V8, just TDI
3rd low and BOOT IT
Old June 26th, 2007, 09:57 PM
jdempsey
Jason Dempsey
94/ D90/ Red
need help anyone out there
Persistence, there is no substitute
Old June 26th, 2007, 11:07 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Not really but technically yes they are.. If I recall, and I will look it up to verify, the manuals say there should be 2 of those for the V8s. You are only supposed to use them right before going into deep water and remove them right after. My 94 had them as does my 97. I dont recall which manual I saw them in but I do remember reading that the V8 do use them if you follow the "letter of the manual law".
Edit: NM.. I must be totally wrong. I just read through both the manual for my 94 and the 97 and didnt see any reference to them. I must have had a copy of the directions for placement of the wading plugs printed out for some reason or looking at it on a Rave CD or something because I rember reading about those plugs for V8 use and seeing the diagram.
With wading plugs?
Chris von C
[/size]
Old June 26th, 2007, 11:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That is clearly the lube fill plug to an oscillating latrine brush with a left handed strobal bar.
Old June 27th, 2007, 12:05 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Trick answer, Kevin. They NEVER made left handed strobal bars, only right handed ones on account of his second cousin that lost his left arm in the water balloon accident!! HA! Almost had us with that one! ;-)
Old June 27th, 2007, 07:05 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i used them om my 300 TDI when i rememberd. looked everywhere on the V8, no weep holes
3rd low and BOOT IT
Old June 27th, 2007, 09:46 AM
pcscharfe
pcdefender
D90/NAS 110
Thanks for the quick responses guys! It sounds like a keeper, though not sure if it is truely useful or even where it gets screwed in on a V8...
Chris, if you run across those instructions for placement of the plug it sounds like everyone here would benefit.
Thanks to all.
Paul
Old June 27th, 2007, 09:49 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The placement is at the bottom of the bell housing--it is to keep it from filling with water and mud and getting that debris on the clutch. When you are done wading, you remove it so that any debris that may have gotten in can drain. I never use mine and most peoples are located in their tool roll if they have one.
Old June 27th, 2007, 12:19 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
Thanks Chris.
Old June 27th, 2007, 01:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Next tricky question , what thread ar those plugs ???
- Charles Eames
Old October 14th, 2009, 09:43 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Bringing this back from the dead. Anyone know the thread size on the bell housing wading plug for a V8?
Old October 15th, 2009, 09:28 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I'm thinking M10x.125
Keith
Big, Red and ... aaa Red..
Old October 15th, 2009, 01:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'll try to check later today, but think this is it.
- Charles Eames
part
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
