Ideas for front Wiper motor Upgrades? - Defender Source
Old December 8th, 2009, 12:18 AM
Daringer
Darin Gardner
1997 D90 SW
Has anyone upgraded or modified the front wiper motors/ assembly/ mechanics to eliminate the excessive amount of mechanical noise they make? I am on my second 97 and swore to myself that I would research and install an alternate to the dated technology.
I have already searched the forums and have not found any leads on members that have taken on such a project. Can the motor and or assemblies be switched out with another (quieter) Land Rover wiper motor?
Thanks in advance for any leads or ideas.
Old December 8th, 2009, 12:24 AM
ECR fits TD5 style wiper motors.
Old December 8th, 2009, 07:38 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I used a TD5 wiper motor(got it off a bulkhead I bought) to replace the one in my D90, but it didn't look any different than the one it was replacing.
Old December 8th, 2009, 07:50 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yes we do, but that is just as a replacement part. It is basically the same design and same system. The motor itself is identical.
The reason we go to the later model stuff is to get rid of the NAS style rod/spline drums that tend to get a lot of slop and or corrode. This cures the wiper slop issue, but would not address the noises.
If your 90 has a ton of wiper miles and things are dry (no grease left) the wipers can be very loud.
If you go through and replace any worn parts and lube things up nicely it would be quieter, but if you want silent you'd need to come up with your own design.
Even with 3 miles on them you can still hear the wipers working.
Email:
Old December 8th, 2009, 08:12 AM
Hey, at least they don't have vacuum wipers.
Old December 8th, 2009, 01:39 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I havent searched but am curious if anybody has upgraded them to have an intermittent setting. Or do later ones have this?
Old December 8th, 2009, 01:50 PM
NAS D90's have an intermittent feature - you press down on the stalk. Now variable speed intermittent wipers are still a DAT (Driver Assisted Technology).
Old February 28th, 2011, 04:57 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Wiper Replacement Suggestions
My wipers just died in the pouring rain. Perfect timing. It is as if there is a glitch because every once in a while they'll come on then stop again. What is my best bet? Replace it with a TD5 wiper motor?
Old February 28th, 2011, 05:35 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Sounds like the contacts on the stalk inside the steering column fascia finally burned out.
Old February 28th, 2011, 05:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I was actually inside the steering column over the weekend fixing some wiring. Is it possible that I messed with these contacts?
Old February 28th, 2011, 10:02 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
...and now they work again!
What's up?
Old February 28th, 2011, 10:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sounds like a loose connection. Open up the steering column and check the stalk wires
Old February 28th, 2011, 10:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I will check this weekend.
They were on for about 10 seconds then stopped working again.
Old February 28th, 2011, 10:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
I bet it is a wire. Had the same issue with my 110 and the rear lights. Found the loose wire and reconnected it.
Old March 1st, 2011, 11:52 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Is the wiper circuit and rear defroster interconnected? It was working this morning for a few minutes when starting from cold. The rear window defroster was also working. Then when the wipers cut out the rear window defroster cuts out too. It seems like something is overheating and turns off somewhere.
Old March 1st, 2011, 02:17 PM
airbornrover
William Skidmore
SIII 109 SW
When the wipers started going out on me it was the contacts had worn out from wear and tear over the years. When you are working the stalk up and down it completes a circuit(anyone chim in for the wrong terms) cause it is contacting a separate wire on its own little circuit. Or the little ball bearing ( I remember correctly?) has worn a grove so that its not able to make proper contact anymore thats where the clicking comes from.
Old March 1st, 2011, 02:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
So I need a new switch assembly?
Why is my rear window defroster interconnected with my wipers?
motor
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
Ideas on building a 110 draaronr Defender Technical Discussions 4 July 14th, 2004 09:59 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
