ID the leak - Defender Source
Old September 9th, 2013, 08:43 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
ID the leak
Went to pull the 90 out of the extra garage where is has been for 1.5 weeks and saw a huge puddle under it. Appears to be oil, but is dripping off of the brake drum. Did not have the time of clothes to spend much time under it...but could the rear main run down the frame/driveshaft this much when standing still, or is it a t-case leak? Also posted a pic of the fluid I wiped up and it smelt a bit t-caseish. The question is...what typically leaks and runs down to the brake drum?
ID:	79377   Click image for larger version
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old September 9th, 2013, 08:46 PM
if you are talking about the parking brake drum, it's is 90W oil from t-case. it's time for you to replace your rear output shaft seal. there is nothing else it could be from that spot. Unless you left a bottle of crisco oil in the backseat and it spilled. those are your options.
------ Follow up post added September 9th, 2013 08:47 PM ------
BTW, great writeup on replacing it on Dweb. No removal required. Did it myself in an afternoon.
Mark Kellgren
KM4BOR
Old September 9th, 2013, 09:19 PM
Exactly what Mark said...had to do the same for mine, it was amazing how much it leaked. Get a new nyloc nut for it while you're at it, the parts I needed were:
(1) FRC7043 oil seal - transfer case output
(1) FRC2464 felt washer
(1) NY120041L nyloc nut
And I'm sure the brake shoes are soaked, but just use a whole can of brakleen to clean them up and you should be ok since it's just the parking brake (or if you want to play it safe get new shoes...I did not and it's been fine).
Old September 9th, 2013, 09:21 PM
molonlabedoc
Vincent
1987 D90
I am chasing down a very similar leak. Looking online for this write up but so far notta. Overlander do you recall where it was?
Old September 9th, 2013, 10:06 PM
This is for front bearing, but includes seal. Front and rear are pretfy much the same.
http://www.discoweb.org/tcasebearing/index.htm
Mark Kellgren
KM4BOR
Old September 9th, 2013, 10:07 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
http://www.defendersource.com/forum/...ad.php?t=32345
This thread has links for both ends.
Old September 9th, 2013, 11:08 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If it has a sickening smell it's good old gold colored 90wt as suggested above.
Another clue is the gold color seen in the photo.
Used crankcase oil is generally black in color and mostly has more of a light smell of acid with a hint of burnt rubber (at least to my nose).
Hope this helps.
RDavisinVA
Old September 10th, 2013, 01:44 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
It was dripping off the parking brake. Thought is was too clean for engine oil and smelled like t-case fluid...looks like I have some work to do...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old September 26th, 2013, 12:36 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Been busy, so sent this to my mechanic...ended up being a loose nut and a crushed felt washer...super easy fix!
Had the parking brake pads replaced since they were toast and the t-case leak was cheap!
$230 with the brake pad replacement!
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old September 26th, 2013, 01:11 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Parking brake pads were very expensive last I checked. Do you have some details over how much that piece of the puzzle costed you and where it came from?
MonLand
1995 D90 NAS
1996 Discovery NAS
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
