I tthink my starter is almost toasted, can someone confirm? - Defender Source
Old September 7th, 2012, 03:59 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
It was happening about once a month but today it has done the same thing twice. When I go to turn it over I get a fast loud clicking and it won't catch and turn over the motor. Eventually it will work but it takes a few tries. Any suggestions for the best deal on a starter, can they be rebuilt? It's a 200 Tdi
Thanks, Jason
Old September 7th, 2012, 04:11 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Sounds more like your battery is toast. but could also be your starter. Check your voltage at the battery first before you put in a new starter
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 7th, 2012, 04:17 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Take your starter apart. When mine started acting up, I serviced it. Had lots of crud inside and lots of dust.
Now it fires up very fast. They're really simple inside.
Old September 7th, 2012, 04:29 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks, I will check the battery but is a brand new one of the big sears platinum ones and the voltage gauge has been reading normal. I was having a grounding issue but I thought I had that sorted out, I will check that as well before I take the starter out.
Old September 8th, 2012, 07:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Check all the main cables, battery -> solenoid -> starter motor -> ground ->battery.
Make sure all the connections are clean and tight. What you're experiencing could be something as simple as one of those connections becoming loose over time, or corroded.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2012, 10:56 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I think I found the problem, it was the battery ground
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
