I think I need new Catalytic Converters- please help! - Defender Source
Old July 9th, 2011, 10:50 AM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Hi all,
So the defender has been sort of 'missing' here and there the past few months & stalling a little bit, check engine light occasionally comes on & for a little while it smelled like a stink bomb. There is occasionally some 'popping' noises that sound like they are coming from around under the gearsfift or passenger seat vicinity. A little bit of rattling noises too when starting off in 1st gear. Yesterday, the truck would only idle, when I step on the gas it would not rev, but it would almost stall out & if I could get it going, it would only drive about 5 mph. My thought is cats. Anyone think so? And if so, should I buy some universal ones from the local autopart store at $70 each? Thanks!
Old July 9th, 2011, 11:28 AM
What is the code it throws?
Old July 9th, 2011, 11:34 AM
TS888's Avatar
TS888
Tony Sims
1984 110
It does sound like the symptoms of clogged cats. And if it is, I agree there's no reason to spend any more than you must. That said, maybe do a little googling on the performance of various aftermarket options. Any reduction in exhaust restriction would be a good thing for fuel consumption and general performance, and there are aftermarket "performance" cats that claim that benefit.
Tony
1984 110 "Smokey" (sold)
Old July 10th, 2011, 02:12 AM
What does the CEL code read? Sounds like O2 not cats. Does it get better when the CEL comes on? If so, my guess is O2s. Could be any number of things though.
Old July 10th, 2011, 07:52 AM
NoVaKevin
Kevin
sold#1469
Your symptoms indicate cats, but the noises could be from a number of things.
I would start simple- confirm rattle and know which cat is bad, check o2 wiring. The stink bomb smell indicates could be cats or problem running rich/lean. So, it could be your cats, or it could be a fuel problem. Or, even ecu problem calculating fuel/air.
If it were me and I thought it was the cats I would use cheap generic. If you replace them, and its not the cats, then there is a high likelihood that the new cats could end up going bad real quick because you didnt address the right problem. If you have rattle....it may only be in one cat, so you may only need to replace one.
Take it to a good exhaust shop and they will be able to tell you if the cats rattling and bad. Generally, if the inlet part is black and the outlet is white....they are working fine. A local shop here charges 180 installed cat using generic catco. I dont have a welder and bender or else I would do that type of work myself.
Re-tune ecu without catalytic converters Help! bstraw Defender Technical Discussions 0 December 23rd, 2006 10:48 AM
Only one catalytic converter??? opinions?? cbass Defender Technical Discussions 7 August 10th, 2005 10:30 PM
Replacment Catalytic Converter chrisvonc Misc. Chit-Chat 5 May 3rd, 2005 06:22 PM
Catalytic Converters and Muffler OCD90 Defender Technical Discussions 1 January 19th, 2005 01:24 PM
Catalytic Converter needed for 94 D-90 ripp2002 Defender Technical Discussions 9 December 15th, 2004 06:43 PM
